Re: Super C Engine Help
Posted by El Toro on December 12, 2011 at 10:01:42 from (108.3.225.57):
In Reply to: Re: Super C Engine Help posted by equeen on December 12, 2011 at 04:39:53:
You need to measure the length (7-1/16") of the old sleeves
and the outer diameter (3-7/16")of the sleeve at the seal to get the correct sleeve kit. The sleeve kits used the Farmall A's, B's C's and the early Super A's had sleeves that measured 6-7/8" length and 3.3125" on the outer diameter of the sleeve at the seal. They can not be used in your block. Hal
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
