Re: Farmall H power problem
Posted by TMonton on December 12, 2011 at 14:43:57 from (75.46.64.176):
In Reply to: Farmall H power problem posted by ireland.29 on December 12, 2011 at 06:05:44:
I'm thinking if you can pull well in lower gears, ignition and carburetor has to be right.
Try pulling the tractor (not running ignition off) in road gear. Another H would pull that easy anyway and see if there is too much drag is against the transmission/rear end ??
I'm seeing something similar in a tractor here to include that rear end howl. I just know once I dig in it will add up quickly.
These gentlemen are correct too. As a kid we used to pull hay wagons for miles along hilly roads and we could lay into them pretty good. The H was always a good puller.
I always wanted a step between 4th and 5th but that's going off topic.
