Re: push pull switch 706
Posted by FC Andy on December 12, 2011 at 15:29:05 from (74.126.84.52):
In Reply to: push pull switch 706 posted by crystal allis on December 12, 2011 at 13:14:16:
From the 450 series and up they should have the same Key. Now, I'm not trying to be a smart A$$, but the way I read your post, the engine is shutting down, which has nothing to do with the key switch/ push pull switch. Now, if only the electrical is going on and off, you may have the culprit. Dose it make a difference if you jiggle the switch? And- I once had gauge lights that I could not make work. Nothing made sense. Turns out, the multi-connecter behind the fuel tank and ahead of the steering column had corroded the connections. Took it apart, sprayed some battery terminal cleaner in there, waited a few minutes, blew it out, plugged it back together, and Viola! The gauge lights worked, and, Ignition power worked better, too. Less fussy on key position. Just a thought. -Andy
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
