Re: H Thermostat
Posted by David G on December 12, 2011 at 16:36:01 from (205.215.206.18):
In Reply to: H Thermostat posted by George Rausch on December 12, 2011 at 15:43:48:
Pressure is regulated by the radiator cap. The thermostat is well worth any risk of additional leaking.
Just having a thermostat closed will not raise radiator pressure because the thermostat is on the discharge of the water pump, and subsequently the head.
