Re: Rough running 560 gas
Posted by Brownie 450 on December 12, 2011 at 19:15:14 from (66.43.241.198):
In Reply to: Rough running 560 gas posted by brian(MN) on December 12, 2011 at 15:28:18:
Have you checked for adequate gas flow from the tank to the carb?? Might check the condenser, also. How about ignition wires, & the dist. to coil wire? Check for a loose connection in the switch to coil primary wire or the voltage dropping resistor--even the switch??
Air cleaner cup filling with dirt enough to shut down air flow? Would blow black smoke, though if this were the case.
