Posted by pete 23 on December 13, 2011 at 10:38:00 from (74.32.238.142):
In Reply to: head gasket seal posted by Pat Connors on December 12, 2011 at 12:20:58:
I would do a cyl pressure leak test to see if it is leaking internally. It has become more and more of a problem it seems with the sleeve flange height being too high with all the aftermarket sleeves. If you look at the shape of the head gasket you will note it follows the contour of the combustion chamber, not the sleeve flange, so there fore it crosses the flange in four spots and will leave a gap too large for gasket to compress if sleeve flange is too high.I personally like them to be no more than .002 but .004 should work. Friend had a 300 last year, had .008 and it leaked immediately. A pressure test will give you peace of mind if it checks ok or tell you tear down is needed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
