Re: Farmall 826 injection pump
Posted by pete 23 on December 13, 2011 at 16:45:26 from (74.32.238.142):
In Reply to: Farmall 826 injection pump posted by jpavao1066 on December 13, 2011 at 14:37:12:
It normally only takes a couple of turns at most to reach the max that pump will put out with out some internal work done. If the fuel pressure is not up to snuff you could be short of fuel though and it is easily adjustable from outside if original pump. You need to be certain of your fuel flow first off and then with a gauge hooked up you gently tap the end plug of the regulator piston to increase pressure. If you go too far, well, then you have to take regulator apart and tap plug back out. Need to look up specs though and also a good idea to observe the speed advance with a window on pump while doing this so you would need some knowledge of what to look for.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
