Re: Farmall H power problem
Posted by Janicholson on December 13, 2011 at 17:46:00 from (96.24.99.126):
In Reply to: Farmall H power problem posted by ireland.29 on December 12, 2011 at 06:05:44:
If the cam gear is coming loose, or the key is shearing, it will be a dog. Pulling the Valve cover and using a dial indicator on the #1 valves, and getting a degree wheel on the pulley is the only way to check reliably to determine if it is off. If it has a live hydraulic pump on it (in front of the distributor) it could be an issue. Jim
