Re: Can you identify this tractor?
Posted by IH fan on December 13, 2011 at 20:06:21 from (99.151.38.223):
In Reply to: Can you identify this tractor? posted by BentleymnNov201180 on December 13, 2011 at 19:21:09:
Dad had one that didn't give him any problems, but then he was only farming 100 acres at the time and didn't work it all that hard. Pulled a 3x16" plow and 11 1/2' Kewanee disk and moved big round bales with the Fast Hitch (F-H drawbar welded on a 3 point bale mover). One of my nephews still had it the last I knew.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
