Re: Can you identify this tractor?
Posted by John M on December 14, 2011 at 06:40:11 from (68.115.194.228):
In Reply to: Can you identify this tractor? posted by white halftrack on December 13, 2011 at 19:21:09:
Since I dont see the tag, maybe you could post some part numbers, surely someone will be able to easily tell from those. Looks like a 560 to me.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
