Re: IH 966 Injector pump
Posted by pete 23 on December 14, 2011 at 10:55:39 from (74.32.238.142):
In Reply to: IH 966 Injector pump posted by craigreavley on December 13, 2011 at 06:47:46:
Seeing as how getting a lot of different suggestions I will throw in here also. What I do if pump has been working, not totaled, is line up to correct timing mark, remove pump drive front cover, remove three bolts on pump drive, remove all six injection lines from head of pump, pull throttle wide open, turn pump with wrench and see which outlet pump injects fuel. Then you know which cyl you are on. The reason I developed this method was we had a lot of problems with those pumps under warranty and you could not break a seal or it voided warranty. When out of warranty, I just take off the side cover.
