Re: 240 will start but not run
Posted by old on December 14, 2011 at 14:41:12 from (209.86.226.19):
In Reply to: Re: 240 will start but not run posted by pheel on December 14, 2011 at 12:35:51:
Few people do know about that and the bad thing few also believe it and think they can test the charging system by unhooking a battery cable when the machine is running and be ok. Well first off unhooking it can burn out the diodes in the alternator which in turn then puts out AC current and also tells the V.R. to put out max volts/amps and that is enough to kill which either way is not good since you can figure replacing it is $50 or so and well life is priceless
