Re: Can you identify this tractor?
Posted by D Slater on December 14, 2011 at 16:43:22 from (184.15.30.71):
In Reply to: Re: Can you identify this tractor? posted by white halftrack on December 14, 2011 at 10:27:29:
Yes a 60 model would have the parts in it from the factory. Check the serial # though for serial # 23926 or higher.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
