Re: 240 will start but not run
Posted by mkirsch on December 15, 2011 at 05:20:28 from (64.80.110.74):
In Reply to: 240 will start but not run posted by pheel on December 14, 2011 at 11:41:41:
Watch the charging system after you add the battery.
Like the other guys said, trying to run it without a battery could have ruined the alternator. If it's putting out 90 Volts, it will cook the battery, and possibly cause the battery to build pressure and explode.
IIRC the battery on a 240 is behind the seat. The only place worse than that to have it explode is between your legs like it is on a 544. Yowzers.
You're probably okay though. If the tractor wouldn't run without the jumper cables, the alternator wasn't doing anything yet.
