I figure it is probably stuck, blown headgasket, or stuck valves for the reason it was off. Because I has sat like that my plan is to remove head and have it boiled as I would guess most of the dust and dirt have accumulated from being open. If It checks out with no cracks, plane it, new gasket and install. I will also pull the pan and see what is there. While off I will run a cleaner down any hole to get any other dirt, dust out. Because nothing else looks pulled, I am leaning towards it having some stuck valves as the reason it is somewhat apart. If they were intending to pull the head, they would have disconnected carb at least. Hard to say. With the exception of the fast hitch lift arms being a little bent, so far it looks somewhat straight. Matching tires, look 50 to 75. I hope the rest of the pieces are there. Jason
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
