Re: Cub's with blue stripe decal
Posted by screwstick on December 15, 2011 at 12:57:46 from (174.24.3.128):
In Reply to: Cub's with blue stripe decal posted by REDCUBIH on December 15, 2011 at 10:24:47:
To clarify just a bit, there were many improvements in HP in the Cubs from '47 - '79. But as to the original question as I understood it, there was never a time when IH manufactured two different HP cubs at the same time but used different decals to differentiate them, that is simply not true.
The increases in RPM was only one way that IH upped the HP in the C-60 engine, along with the increases came aluminum dome pistons, larger carbs and manifolds, and a different camshaft. The final Cubs had a high idle of over 2000 RPM's, compared to the original 1600 RPM. Hardy scary considering the C-60 power units turned even faster, and the Palmer Marine P-60 (IH Cub engine) turned over 3k.
