Re: Farmall super C
Posted by Janicholson on December 15, 2011 at 14:45:27 from (67.72.98.45):
In Reply to: Farmall super C posted by I luv farmalls on December 15, 2011 at 14:15:06:
If it is a mag, it might have a hanging impulse coupling. If it is a distributor, It might be a weak coil, or a bad (high resistance) ignition switch or connection in the wires.
Check coil voltage when cranking if less than 9 volts on a 12v system, or 4.5 volts on a 6 v system it might have a hard time starting. When pulled there is full voltage. Jim
