Re: Updates to Can you Identify this tractor model
Posted by IH fan on December 16, 2011 at 04:53:26 from (108.73.29.1):
In Reply to: Updates to Can you Identify this tractor model posted by El Toro on December 15, 2011 at 05:53:13:
For $900 you certainly didn't get hurt... if nothing else, you could part it out and make good money, but it looks like a good restore candidate. Engines are one of the easier things to fix or replace if that's all that's wrong with it.
