Re: Farmall super C
Posted by El Toro on December 16, 2011 at 05:17:51 from (108.3.225.57):
In Reply to: Farmall super C posted by I luv farmalls on December 15, 2011 at 14:15:06:
I would second what Jim suggested you're probably dropping the voltage too much using the starter. Your battery may be getting weak or your starter is pulling too much current and there's not enough for your ignition. Hal
