Re: starting farmall M
Posted by MCOHIO on December 16, 2011 at 07:27:12 from (65.31.51.170):
In Reply to: starting farmall M posted by Finnbair2020 on December 16, 2011 at 07:18:30:
If by chance you have that much water in the carb, you are going to have to drain it.The water will not allow gas to be pulled up through the venturi and jet. I would also check in to a rebuild kit for the carb if you have never had it apart.Some people will shy away from it but using laquer thinner is the BEST carb cleaner there is.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
