Re: 706 gas dies
Posted by Brownie 450 on December 16, 2011 at 08:33:38 from (66.43.241.198):
In Reply to: 706 gas dies posted by MattSillinois on December 16, 2011 at 05:26:01:
Russ is right about fuel--check that first.
If that checks out, look into the possibility of the ignition switch - to - resistor wire having a bad connection [down to 1 or 2 strands] or just loose wire in a connector. Also the resistor itself getting weak. Coil could be getting weak, but not likely.
