Posted by old on December 16, 2011 at 09:33:06 from (209.86.226.12):
In Reply to: starting farmall M posted by Finnbair2020 on December 16, 2011 at 07:18:30:
First thing to do is get rid of the in line filter they cause more problem then they fix. If you have the sediment bowl and the screen in it you have all the filter you will ever need. Next check for a good blue/white spark that will jump a 1/4 inch gap. Next pull the drain plug out of the bottom of the carb and make sure you have a good steady flow of gas. Let it flow for a few minutes and catch it so as to make sure it doesn't have water or dirt in it. If you have good spark and good flow try a hot wire to see if you maybe have a switch going bad or a wiring problem.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce
... [Read Article]
Latest Ad:
[More Ads]
