Posted by Owen Aaland on December 16, 2011 at 09:50:49 from (216.47.33.169):
In Reply to: Farmall super C posted by Janicholson on December 15, 2011 at 14:15:06:
If the condenser is only marginal and not failed completely it can function enough with full battery voltage to allow the engine to run. While cranking the voltage available drops down enough that there is not enough voltage available from the coil to, provide a good spark. A twelve volt system that uses a bypass on the resistor while cranking will not have this problem because the available voltage will actually be more than what is available during normal operation.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
