Re: Paint Prep
Posted by GordoSD on December 16, 2011 at 16:19:19 from (216.106.241.112):
In Reply to: Paint Prep posted by Jim Paterson on December 16, 2011 at 10:07:09:
Sandblast the hood, tank, grill and fenders. I've done three Farmalls, sheetmetal came out absolutely flawless. Result of hammer and dolly work, filler, epoxy base primer and Priming and block sanding 5-6 times will do.
At a minimum sandblast the areas of sharp corners and curves, tank seam, entire grill, there's no way to sand or strip all those edges.
