Re: Ignition wiring for 560
Posted by Janicholson on December 16, 2011 at 20:04:08 from (67.72.98.45):
In Reply to: Ignition wiring for 560 posted by RAM560 on December 16, 2011 at 18:56:22:
The ballast is wired in series with the ignition Key and the coil. (if pos ground, the neg of coil)
there may be a wire from the Starter solenoid that is marked "I" this goes to the distributor side of the coil to bypass the resistor when starting. Jim
