Re: Is this enough spark
Posted by Bob M on December 17, 2011 at 08:09:45 from (67.240.168.45):
In Reply to: Is this enough spark posted by Ft Steele Tractors on December 17, 2011 at 07:08:35:
Pull the wire from the center post on the dist cap and put your tester (or a good spark plug) on the end.
Now while crank the engine - you should get a fat, blue spark every half revolution of the crank.
If you do, problem is with the cap/rotor/plug wires. But if spark is still weak be looking for a problem with the points (including point gap), condenser, coil, etc.
