Re: Farmall A overheats
Posted by Janicholson on December 17, 2011 at 12:38:31 from (199.17.6.212):
In Reply to: Farmall A overheats posted by pete w on December 17, 2011 at 10:09:50:
Old indicates it might be over full. I agree. The coolant should be covering the tubes in the top tank, by about 3/4 inch. Full is bad. There is nop expansion tank, so the expanding water must go out the top if over full. Jim
