Re: Farmall A overheats
Posted by gene bender on December 17, 2011 at 13:31:30 from (207.177.56.222):
In Reply to: Farmall A overheats posted by pete w on December 17, 2011 at 10:09:50:
Your problem is the block is plugged where the coolant comes down by the sleeves and therefore the coolant cant cicculate as it supposed to do. Best fix is remove the radiator then you can remove the bottom outlet. mNow with compressed air and some stiff wire you can clean the block out. those holes are about the size of a nickel but using air and water pressure you can get them cleared. Using a hose with plenty of pressure and flow forcing water in thru that botto9m outlet you can backflush and get the crud out. You will be surprised at the junk you will find.
