Re: Farmall A overheats
Posted by old on December 17, 2011 at 14:31:54 from (209.86.226.60):
In Reply to: Re: Farmall A overheats posted by SD Jay on December 17, 2011 at 10:33:14:
Only time that is true is if all your going to do is drain and fill the cooling system and then not start the engine so as to get the coolant flowing so yes if you do not run the engine no the anti-freeze will not mix up as well so you might need to premix it
