Re: IH 3414 Diesel no fuel at injectors
Posted by supergrumpy on December 17, 2011 at 15:34:11 from (72.226.44.2):
In Reply to: IH 3414 Diesel no fuel at injectors posted by MJohnson on December 17, 2011 at 13:14:18:
there should be an internal fine mesh filter inside rear portion of the injector pump, where the line comes down from the filter, remove line then unscrew the larger plug, keep everything spotless as you are after the filter
also, there are 2 plugs on the injector pump that have to be bled, just in front of the lines going up to the injectors, do lower one first while working the pump, upper one is on the lid of the injector pump
