Re: farmall md overhaul
Posted by Janicholson on December 17, 2011 at 19:41:17 from (96.24.99.126):
In Reply to: farmall md overhaul posted by jim warehime on December 17, 2011 at 17:44:45:
If you replace parts that are beyond reuse, and reuse every component from springs to valves and timing gears, it could still run into 3000. If you spend time finding unbelievable deals it might be less. If it is using oil, and getting difficult to clear up on diesel, It is time. Do not let the head work recess the valves into the head, they are critically placed for proper compression. Jim
