Posted by John T on December 18, 2011 at 06:32:10 from (173.243.181.15):
In Reply to: H {Problems posted by FBH44 on December 18, 2011 at 05:32:00:
QUESTION
Is there a way to masure it or test the regulator?
One indication of charge rate is to measure the BATTERY voltage when shes not running n just setting there, should be around 6.3 volts, but then runnign at fat RPM IFFFFFFFFFF the charging system works it should raie to at least 6.5 to near 7 volts depends on RPM and condition of genny and battery
The VR cant work right UNLESS ITS WELL GROUNDED check that
Sure it has a VR instead of a cutout relay and LHBD light switch charge controller???
See my TTOUBLESHOOTING PROCEDURE linked below to diagnose charging problem and see if cause is genny versus VR or relay problem
QUESTION on plugs
It can reduce premature fouling is you dont run carb richer then necessary,,,,,,,,,,,use hotter heat range of plugs,,,,,,,,,use wire core plug wires,,,,,,,,,,use T stat or radiator air restrictions to get and keep temp up to 180 or so,,,,,,,,,,good hot spark,,,,,,check timing,,,,,,,try NON resistor plugs,,,,,,,,
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
