Re: H {Problems
Posted by charlie M on December 18, 2011 at 06:37:24 from (74.34.200.218):
In Reply to: H {Problems posted by FBH44 on December 18, 2011 at 05:32:00:
Couple of things on charging - could be the battery depending on how old it is. If it charges up when running and looses charge sitting you either have a bad battery or a short somewhere draining the battery. If its an older battery it will loose cranking power when it gets cold. You can check the voltage at the battery with the tractor running to see if its the charging system. I forget the exact voltage but I think on a 12 volt system it should read around 13-14 volts. Do have an amp meter on the tractor - if so does that show a charge. One way or another you need to find out if its the charging system or the battery or maybe both.
