Re: H {Problems
Posted by riverbend on December 18, 2011 at 06:57:12 from (74.37.49.140):
In Reply to: H {Problems posted by FBH44 on December 18, 2011 at 05:32:00:
A bad voltage regulator can drain the battery while the tractor is off. I forget which set of points does what, but the one that is supposed to pop open when you shut the tractor off can stick.
As far as the plugs, are the plugs sooty or oily ? Soot is fuel, oily is, welll, oil.
Greg
