Posted by El Toro on December 18, 2011 at 06:59:30 from (108.3.225.57):
In Reply to: H {Problems posted by FBH44 on December 18, 2011 at 05:32:00:
Use a volt meter and check your charging voltage across the battery terminals with the engine at 1/2 throttle or better. Should see 14.0 to 14.5 volts on your volt meter. Your regulator is ok if you have that much charging voltage. You should also check your battery's specific gravity in each cell using a hydrometer and compare the readings. Should be in 1.250 range or better. If one is 1.100 you have a dead cell and the battery needs replacing. You can get a hydrometer at most auto parts store and it will also check your antifreeze to see if you have enough protection against freezing. They shouldn't be that expensive. Here's the hydrometer I used at work and they gave it to me when I retired. Hal
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
