Re: do i need a bra??
Posted by Janicholson on December 18, 2011 at 11:07:25 from (199.17.6.80):
In Reply to: do i need a bra?? posted by mike paulson on December 18, 2011 at 09:05:20:
The thermostat housing is cast with a bypass port around the t-stat. It is way too large for proper warmup. I believe it needs to be smaller. a 1/4" hole would restrict flow and assure warmup. I would braze the hole shut, then drill it to 1/4". Choosing a 180 Thermostat that has a nice large flow opening (not necessarily a stock one, even modifying one to fit is OK) would assure full flow. Some of the OEM I have seen are puny in flow (valve) diameter. Jim
