Re: How to Remove the Bolster
Posted by rustyfarmall on December 18, 2011 at 13:22:05 from (216.248.71.224):
In Reply to: How to Remove the Bolster posted by Nebraska Cowman on December 18, 2011 at 12:36:14:
First, I want to warn you that the front bolster is HEAVY, and also TOP heavy, so use a hoist or lift of some kind. Having said that, see if you can wedge something between the frame rails and motor mounts and spread those rails just a bit. It doesn't take much, but there is rust and dirt built up between the frame rails and the bolster. If it wasn't for the crud, that bolster would pretty much just slide right out.
