Re: Horsepower ratings
Posted by Dr. Bert on December 18, 2011 at 14:01:15 from (72.36.56.185):
In Reply to: Re: Horsepower ratings posted by Nebraska Cowman on December 18, 2011 at 12:37:33:
Is this correct? At sea level the higher compression tractor would generate 14% more hp than the standard, however, if you took the higher compression tractor to 5000 ft., its hp would be approximately the same as the standard compression tractor at sea level. I live at 3300 ft., so assume the high compression engine would generate about 4 to 5% more power. Thanks to all for enlightening a dim bulb!!
