Re: The 'new' Farmall M comes home!
Posted by SadFarmall on December 18, 2011 at 22:15:45 from (112.213.158.51):
In Reply to: The 'new' Farmall M comes home! posted by SadFarmall on December 17, 2011 at 13:05:50:
Hello folks and thanks for the comments. To answer the questions/issues brought up. The wheel weights were fitted to the wheels on the inside and the wrong side to the wheel centre. It meant that the weights had to be removed to undo two of the bolts which clamp the wheel to the axle. I have now moved the weight to the outside and fitted it convex side to the wheel. Picture attached.
third party image
The jack was made by Trewalla Brothers in Trentham, Victoria (company now defunct). It's full name is a Trewalla Cast Iron Monkey. It came with various 'spears' which mean it can be used to lift something a few inches off the ground or be placed under building beam fifteen feet off the ground.
The oil filter is standard for Australia so far as I know and was also fitted to some Australian Farmall H tractors. The pressure gauge does not work properly, it always shows pressure above minimum when the engine is stopped. As to the best way to view Australian Farmall pictures, may I submit one here?
SadFarmall
third party image
This post was edited by SadFarmall at 22:16:51 12/18/11.
