Re: How to Remove the Bolster
Posted by 400D Guy on December 19, 2011 at 14:00:18 from (69.76.146.214):
In Reply to: How to Remove the Bolster posted by Paul from MI on December 18, 2011 at 12:36:14:
Thanks, and I'm trying to think ahead.
Got the bolster off, removed top and bottom bushings, will get final bushing tomorrow. Someone had shimmed the top bushing next to the cast with some sheet metal -- guess the shaft wore through the previous bushing and ate into the cast. The worm gear ball bearing has about 1/32" side play -- that's probably not OK. The upper bolster thrust roller bearing was full of mud. I cleaned it real well, but the bearings and everything is real loose. Bearing balls appear pitted. Called IH about cost and they want $80 and $90 for them. I had to hang up and think about it.
