H with no power previous post follow up
Posted by gbs on December 19, 2011 at 19:15:57 from (66.83.123.242):
remembered a situation with a 4020 that had the pump off and rebuild, then rechecked twice also a no power problem ,turned out to be the cam gear had gotten loose on the shaft and wore the key to the point it was retarding the cam timing causing the problem, sorry about the late reply must have to do with age
