Posted by Janicholson on December 19, 2011 at 19:25:52 from (96.24.99.126):
In Reply to: Drilling a shaft posted by clint s on December 19, 2011 at 18:32:15:
Find a piece of thin wall tubing about 8" long, that fits on to the splines pretty well. Weld or braze a thin sheet metal cap onto the end. clamp this on the splines with a U clamp so the cap is 2 inches out from the intended hole. Set up a support at the capped end for a sharpie marker and turn on the PTO. use the marker to "dot" the center of rotation. (the pipe need not be too centered, you are making a center.) Use a small drill to pierce that dot, then go bigger until about 1/4" dia. Then put your drill in the hole and drill the intended starter hole in the PTO with the PTO running if there id no centering hole in it to begin with. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
