Posted by Owen Aaland on December 19, 2011 at 22:05:03 from (216.47.34.100):
In Reply to: m vibration posted by thetractorfreak on December 19, 2011 at 17:30:08:
Unless there is a piece of the flywheel missing the problem would more likely be in the pressure plate assembly. If I didn't see anything obvious I would remove the clutch and run it to see if it changes the vibration. Before removing the clutch you may want to rotate the PPA in the flywheel either 120º or 180º to see if that helps. If necessary you can balance the PPA by putting washers on the mounting bolts where it is light.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
