Re: Jerking Farmall 706
Posted by Pat-CT on December 19, 2011 at 22:17:53 from (24.250.19.52):
In Reply to: Jerking Farmall 706 posted by Cory Schmidt on December 19, 2011 at 18:47:04:
I check the hydraulic system first, You could be losing pressure, thus causing the clutch to disengage. Or your t/a could be out of adjustment, refer to the manual on how to adjust the t/a. However, If you do decide to replace the t/a I would recommend that either you A have someone that knows what they are doing do (A t/a Needs to be properly adjusted, If you adjust it the wrong way it will soon again fail/slip) Or if you don't know anyone that knows their way around a T/A Pick up a service manual and post up here if you have any questions WHATSOEVER
