Posted by Janicholson on December 20, 2011 at 06:49:20 from (199.17.6.10):
In Reply to: Re: Drilling a shaft posted by clint s on December 20, 2011 at 04:19:00:
With this data, there is a need to grind off the nub flat. If the material is incredibly hard (it might be) EDM could be the only way to get it done, That would require it being removed. If it can be drilled, Putting a pointed diamond burr in a dremel tool in a bracket supported in a rigid clamping system centered on the end of the shaft. Drive the gearset from the other end while holding pressure on the dremel. This ground hole will be the center. Now do as described below, or set up a fixture to hold the drill axially with the shaft. Jim
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
