Re: Farmall 706
Posted by Nate V. IA on December 20, 2011 at 07:47:02 from (173.215.42.82):
In Reply to: Re: Farmall 706 posted by W6tractor on December 19, 2011 at 18:53:30:
PTO lever is behind the seat on the right, it pulls up and kinda "snaps" into position. My 706 doesn't have a cab but some I've seen with cabs had a window you had to open to operate the PTO.
Nate
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
