Re: M jumping out of 5th gear?
Posted by mkirsch on December 20, 2011 at 10:32:26 from (64.80.110.74):
In Reply to: M jumping out of 5th gear? posted by BigTone on December 20, 2011 at 10:15:41:
Could be any of a bunch of things.
People tend to try to shift from 4th to 5th on the fly, and GRIND the gears horribly. So, it could be the slider for 5th gear is worn.
Could be bearings too. 5th is direct drive through the transmission to the differential and it puts a lot of stress on the transmission main shaft. If there's play in the bearings holding that shaft, it could walk out of gear.
