Re: farmall M charging problems
Posted by Janicholson on December 20, 2011 at 12:41:23 from (199.17.6.10):
In Reply to: farmall M charging problems posted by boxchevyman on December 20, 2011 at 11:30:11:
They do not need any polarization ever. (no offense to the other responder) Some times a connection, or the amp meter itself go bad. Make sure these are good and all connections clean. With the #2 terminal hooked to the BAT terminal on the alternator, start the tractor, then use jumper with a female spade terminal on it to jump from the #1 terminal to the Bat terminal (same place) Watch the charge (amp gauge, or better yet a needle style volt meter on the battery. If it does not charge, there are internal issues, or it is not grounded well. Jim
