Re: timing sweey spot on Regular
Posted by oldiron29 on December 20, 2011 at 14:03:55 from (74.88.11.200):
In Reply to: timing sweey spot on Regular posted by Super-H-Mike on December 20, 2011 at 13:45:36:
Mike, The mag should click at TDC Full advance!
The pin that you engauge in your crank should be horizontal at TDC. Crank it and listen for the click is it at TDC? That is a starting spot with your timing. The float in the carb can be a real problem if it is not floating good. I have had no luck with the cork floats and the gas we use these days. I have changed most of mine over to brass floats. If it is getting to much gas it will flood easy. I have one right now that is to lean and I have to choke it 2 times than it starts. I would rather that than flooding.
oldiron29
