Posted by Mich John on December 20, 2011 at 14:45:40 from (98.250.205.187):
In Reply to: m vibration posted by thetractorfreak on December 19, 2011 at 17:30:08:
A vibration at idle and neutral engine run-up (tractor out of gear at idle to max RPM) which increases when as you say...." you throttle up" has to be a first order engine speed related issue and MOST likely due to the flywheel out of balance or the clutch-pressure plate components. Taking the p/p and clutch disc out would tell whether it's one of these (i.e. if problem ONLY there with clutch & p/p installed and goes away with removal, look at these components. If still there with ONLY the flywheel on, look at getting it balanced). If clutch/p.p. related issue, there must be something grossly wrong with either that a visual inspection would find (again something affecting balance;cannot imagine it as a runout issue - clutch/p.p. would have to be grossly misaligned). Does the clutch have sufficient capacity - i.e. if you hold the brakes in 2nd gear and let out the clutch slowly at high RPM, would it stall the tractor? Let us know how you resolve it; am curious.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
